DJI Matrice 400 vs. Matrice 350 RTK: Detailed Upgrade Overview
A Comprehensive Feature-by-Feature Comparison for Enterprise Operations
June 18, 2025
The DJI Matrice 400 (M400) delivers a comprehensive upgrade over the Matrice 350 RTK, offering improvements in flight performance, payload capacity, sensing technologies, transmission, intelligence, automation, and accessories.
1. Longer Flight Time
The M400 offers a maximum flight time of 59 minutes when equipped with a single H30T, L2, or P1 payload—nearly 50% longer effective flight time than the M350 RTK under similar conditions. This upgrade significantly enhances mission efficiency for long-duration tasks such as emergency response, large-area mapping, and corridor inspections.
Model
M350 RTK
M400
Max Flight Time
42 minutes
59 minutes
1、续航时间更长.2025-06-04 19_30_33
2. Enhanced Payload Capability
The M400 supports a maximum payload of 6 kg, with up to 7 simultaneous mounted payloads, compared to 2.7 kg and 3 payloads on the M350 RTK. The aircraft features 4 external E-Port V2 interfaces, with the E4 port expandable into 4 additional ports, increasing multi-payload capability.
Model
M350 RTK
M400
Max Payload
2.7 kg
6 kg
Max Payloads Connected
更大载重,更多挂载数量
3. Faster and More Efficient
The M400 offers superior speed across all metrics. It achieves a flight speed of 25 m/s and route speed of 25 m/s—60% higher than the M350 RTK. It also supports higher ascent (10 m/s) and descent (8 m/s) speeds.
Metric M350 RTK     M400
Max Speed 23 m/s 25 m/s
Route Speed 15 m/s   25 m/s
Ascent Speed   6 m/s 10 m/s
Descent Speed 5 m/s 8 m/s
4. Enhanced Safety and Reliability
The Matrice 400 significantly enhances obstacle avoidance through a fusion of rotating LiDAR, six-direction mmWave radar, and four full-color low-light fisheye vision sensors:
- Rotating LiDAR: Delivers high-precision 3D depth information, enabling accurate environmental modeling even in extreme lighting conditions, including strong sunlight or darkness.
环扫雷达.2025-06-04 19_46_44
- mmWave Radar: Provides strong penetration in rain, fog, and snow, capturing both range and velocity information in real-time.
- Vision Sensors: The four full-color low-light fisheye cameras capture rich visual features such as color, shape, and texture, enabling full-color flight assist displays.
电线级避障.2025-06-04 19_40_43
Thanks to this comprehensive sensing suite, the M400 can detect fine obstacles such as overhead power lines, even when flying at night across mountainous terrain. Its all-weather system provides enhanced operational safety in rain and fog.
At 25 m/s, the M400 can detect and bypass primary grid lines (21.6 mm steel-core aluminum conductors). At 17 m/s, it can detect and avoid both primary and secondary distribution lines (12 mm). This level of obstacle avoidance is a breakthrough for UAV missions in power inspection and high-risk environments.
Sensor Type
M350 RTK
M400
Rotating LiDAR
No
Yes
mmWave Radar
No (optional accessory)
Yes (6-direction)
Fisheye Vision
6-direction binocular
4 low-light fisheye
5. Enhanced Video Transmission
The Matrice 400 is equipped with the new DJI O4 Enterprise transmission system, which offers up to 40 km of range under FCC conditions—double that of the M350’s O3 Enterprise system. It also supports dual 4G dongles for network redundancy and airborne relay for signal extension across obstructed environments.
In addition to the standard 2.4/5.8 GHz bands, the M400 introduces support for a sub-2G transmission band, which enhances signal stability in interference-prone or long-distance scenarios. This sub-2G frequency varies by region—1.4 GHz is used in China, while 900 MHz is deployed in countries such as the United States, Canada, Australia, Japan, Brazil, Taiwan (China), Singapore, and Malaysia. Operators should ensure compatibility with local frequency regulations prior to deployment.
Feature
M350 RTK
M400
Transmission System
DJI O3 Enterprise
DJI O4 Enterprise
Max Range (FCC)
20 km
40 km
Airborne Relay
Not supported
Supported
4G Transmission
Single dongle
Dual dongle
1.4 GHz Frequency
Not supported
Supported
6. Smarter Object Detection
Detection Mode
M350 RTK
M400
Visible Light Detection (Vehicles, Boats, etc.)
Supported (In Smart Track)
Supported
Thermal Imaging Detection
Not supported
Supported
Third-Party Detection Model Integration
Not supported
Supported
Object Counting & Statistics
Not supported
Supported
热成像智能检测-剪辑.2025-06-05 19_30_57
With support for both visible light and thermal imaging, the Matrice 400 offers enhanced detection capabilities when paired with the Zenmuse H30 series. It can intelligently identify targets such as vehicles and vessels, switch between different detection models, and automatically count objects within its field of view.
7. Advanced Automation
The Matrice 400 supports enhanced mission execution features such as real-time obstacle bypass during L2-guided routes, and flight path planning for slopes, geometric structures, and building facades. These capabilities are managed through DJI Pilot 2 or FlightHub 2, greatly streamlining complex operational workflows without requiring constant manual control. In comparison, the M350 RTK supports only basic flight path execution.
Function
M350 RTK
M400
L2 Line Following
Supported
Supported + obstacle bypass
Slope & Geometric Routes
Not supported
Supported
Smart 3D Capture
Not supported
Supported (with P1 payload)
FH2 Mission Planning
Not supported
Supported
8. AR Features for Awareness
The M400 introduces rich AR overlays on the controller screen—visualizing powerlines, route paths, map data, and landing points. Operators gain more spatial awareness and planning clarity, reducing risks during complex operations.
M350 RTK
M400
AR Powerline Overlay
Not supported
Supported
AR Map Display
Not supported
Supported
AR Return Path Projection
Not supported
Supported
AR Landing Point Visualization
Not supported
Supported
AR Area Drawing & Measurement
Not supported
Supported
AR Powerline Warning
This feature automatically detects overhead power lines in front of the drone and overlays clearly visible AR lines on the remote controller screen. Even in low-light or complex environments such as mountainous terrain or densely built areas, operators gain an intuitive visual reference to avoid wire collisions, improving operational safety—especially during inspection tasks.
AR Map Labels
The remote controller can display real-time labels for landmarks, buildings, and roads on the map interface. Users can toggle display categories based on mission needs, making urban operations more intuitive and helping pilots maintain orientation during complex navigation scenarios.
AR Return Path
While executing Return-to-Home (RTH), obstacle bypass, or FlyTo commands, the drone’s planned path is displayed as an AR line overlay. This allows operators to visually monitor the exact flight path in real time, ensuring better situational awareness and reducing the risk of routing errors.
As the drone descends, an AR shadow of the aircraft is projected onto the landing area on-screen. This helps the operator verify whether the current landing location is clear and safe, reducing the risk of hard landings or ground collisions in constrained environments.
AR Drawing and Measurement
Without requiring 3D modeling, users can mark points directly on the controller screen to acquire geographic positions, draw lines to measure distances, and define areas to calculate surface size.
Measurement results can be synced to DJI FlightHub 2 to support collaborative mission planning and team coordination in real time.
9. Intelligent Flight Modes
M350 RTK
M400
Real-Time Terrain Follow
Not supported
Supported
Ship-Based Takeoff/Landing
Not supported
Supported
Cruise Mode
Not supported
Supported
FlyTo Target Point
Not supported
Supported
POI Orbiting
Not supported
Supported
Observed View
Not supported
Supported
  • Real-Time Terrain Following
    This feature enables the aircraft to maintain a constant relative altitude to the ground while flying manually or along pre-defined flight routes.
    It is especially useful in mountainous regions or during low-altitude mapping, ensuring consistent ground sampling distance (GSD) and reducing the need for constant zoom or manual altitude adjustments.
  • Ship-Based Takeoff and Landing
    M400 can take off from stationary or slow-moving vessels and accurately land by recognizing deck patterns.
    This capability significantly expands operational scope to offshore environments such as maritime patrol, wind farm inspection, or rescue missions at sea.
    船上起降.2025-06-04 19_32_58
  • Cruise Mode
    With Cruise Mode, the pilot can set the drone to fly continuously in a given direction at a constant speed—without needing to press the control sticks.
    This mode is ideal for long-distance linear inspections (like pipelines or roads), reducing pilot fatigue and improving path consistency.
  • FlyTo Target
    In emergency or dynamic scenarios, this feature allows the drone to automatically calculate the optimal flight path and speed to reach a designated target.
    It adapts to real-time environmental inputs (e.g., obstacles, terrain) to ensure a safe and efficient approach.
  • POI (Point of Interest) Orbiting
    POI mode enables the aircraft to circle around a designated object or area while keeping the camera focused on it. This function is particularly valuable for structural observation, 3D modeling, and video capture, as it allows stable and smooth perimeter coverage without complex manual control.
  • Observed View
    The system can display previously observed ground areas and the camera center's current location directly on the remote controller map.
    This real-time feedback allows operators to avoid redundant coverage and ensure all intended targets or zones are inspected or captured.
10. Ecosystem and Accessories
M350 RTK
M400
Manifold 3 Onboard Computing
Not supported
Supported
Remote Controller
DJI RC Plus
DJI RC Plus 2 Enhanced
Battery Type
TB65
TB100 High-Density Battery
Battery Station Charge Time
(0 to 100%)
60 minutes
45 minutes (220V)
Tethered Battery Support
Not supported
Supported (TB100C)
配件
11. Spotlight & Speaker Enhancements
S1 spotlight
M350 RTK
M400
S1 Spotlight Beam Alignment
Not supported
Supported
Brightness (Lux @ 100m)
35 lux
40 lux
Dual Spotlight Control
Not supported
Supported
Multilingual Voice Modes
Limited
Supported
AR Directional Broadcasting
Not supported
Supported
V1 speaker
M350 RTK / M300
M400
Max Volume (V1)
127 dB @ 1m
129 dB @ 1m
Effective Broadcast Distance
500 m
700 m
Broadcast Modes
Recording / Text / Audio
Live / Recording / Text / Audio
Howling Suppression
Not supported
Supported
Supported Languages
Chinese, English
Chinese, English, Spanish, Korean, Japanese, French
Simultaneous Broadcast and Transmission
Not supported
Supported
Directional Audio (AR Projection)
Not supported
Supported
Volume Auto-Adjustment
Not supported
Supported
Notes:
* Please check, confirm, and strictly comply with local laws and regulations before flying.
** All specifications listed on this page are based on controlled tests with mass-production DJI M400 units and are for reference only. Results may vary depending on environmental conditions, usage methods, and firmware versions. Please refer to your actual experience.
*** All videos and images shown on this page were captured in full compliance with local laws and regulations. Wildlife footage was taken from a safe distance. All samples are for illustrative purposes only. Please ensure your drone is certified and flight-compliant before operation.
**** The M400 must be activated through the DJI Pilot 2 app before use.
Tags: Matrice 400
Matrice 400 Webinar
