Running a DFR program, or any other automated drone workflow, eventually comes down to one unglamorous question: what happens the moment the battery runs low? For most dock-based systems, the answer is a recharge cycle and a coverage gap that undercuts the whole premise of being "always ready."
DJI Dock 4 is built to close that gap. It's DJI's first dock with automated battery swapping, completing a battery swap in 25 seconds,[2] with an AI-powered workflow in DJI FlightHub 2 that can initiate dispatch after an operator confirms a third-party alert. Here are six things worth knowing about how it does that, and why they matter if DFR or automated workflows are the goal.
Quick answer: DJI Dock 4 is DJI's first dock with automated battery swapping, completing a battery swap in 25 seconds.[2] This reduces battery-related downtime for DFR programs and other automated workflows that need aircraft ready for successive calls, without manual battery replacement between flights.
6 things to know about DJI Dock 4
1. Ready in Seconds for Rapid Response
The drone launches the instant a command is issued, with no pilot on site needed, and flies to the scene at up to 21 m/s.[1] For DFR specifically, this is the number that determines whether the drone beats, matches, or trails the first patrol car. A dock that launches in seconds, every time, is what lets a program commit to "drone first" as a real dispatch policy rather than a best-effort goal.
2. Swap, Relay, Sustain: The 25-Second Battery Swap
This is the headline change: a fully automatic battery swap in 25 seconds,[2] with flight data transferring automatically during the swap. For continuous or back-to-back calls, this reduces battery-related downtime between flights. For missions requiring continuous situational awareness, Task Relay adds a second layer: two aircraft alternate, with one maintaining coverage while the other prepares for the next flight.
3. Multi-Sensor Integration for Greater Versatility
Matrice 5TD puts telephoto, infrared, laser ranging, and full-color night vision on one airframe. For a workflow, that matters because it means the same aircraft handles the night-time emergency call and the daytime infrastructure inspection, with no swapping airframes or re-provisioning the dock for a different mission type.
4. Built-In Radars for Reliable Flight
Matrice 5TD combines three-directional mmWave radar, rotating LiDAR, and six-directional vision sensing to support reliable flight in complex environments.[4] Together with the required DJI O4 Ground Station and appropriate site planning, DJI Dock 4 supports deployment near high-rise buildings and industrial sites, subject to positioning coverage and local conditions.[5]
5. AI-Powered Workflow for Intelligent Operations
DJI FlightHub 2 streamlines the workflow from an alert to a mission. Third-party alerts can initiate a dispatch workflow, but an operator must confirm before the drone is dispatched. FlightHub 2 Copilot turns a plain-language instruction into a flight command, and periodic workflows handle recurring inspection or survey tasks on a schedule, with AI post-processing turning the footage into a report without manual review.
6. Secure and Compliant for Safer Operations
Urban and BVLOS operations must meet local requirements; product safety features can support that process but do not replace operator obligations or required approvals. With the DJI AP1 Parachute installed, Matrice 5TD meets the product requirements referenced for EU C5/C6 and UK5/UK6 operations,[3] alongside flight-controller-enforced custom flight zones and end-to-end encrypted data handling. For a DFR program, these features can support the safety case; the operating route and required approvals must be assessed separately.
Your Questions, Answered
Why does battery swap speed matter for DFR programs specifically?
A DFR program needs the drone airborne on every qualifying call, not just the first one before the battery runs low. A 25-second automated swap[2] keeps the dock in rotation between calls instead of going offline for a recharge.
Can DJI Dock 4 be triggered automatically by a 911 or dispatch system?
Through integration with a compatible third-party dispatch system, an alert can initiate a workflow in DJI FlightHub 2. An operator must confirm the alert before dispatching the drone.
How do DJI Dock 4 and Matrice 5TD support compliant operations in Europe and the UK?
With the DJI AP1 Parachute installed, Matrice 5TD meets the product requirements referenced for EU C5/C6 and UK5/UK6 operations.[3] This does not automatically permit every populated-area or BVLOS flight. In the EU, STS-01 covers VLOS over a controlled ground area in a populated environment; STS-02 covers BVLOS over a controlled ground area in a sparsely populated environment, with applicable observer requirements. Operators must meet all conditions of the relevant scenario or obtain required authorization for the intended operation.
Does Dock 4 need a different drone for day vs. night missions?
No. Matrice 5TD's telephoto, infrared, and full-color night vision are built into the same airframe, so the dock doesn't need to be reconfigured between scenarios.
Get Started with DJI Dock 4
DJI Dock 4 is a fundamental step forward for organizations running automated, round-the-clock drone operations. By combining a 25-second automated battery swap, the multi-sensor Matrice 5TD, and an AI-powered workflow through DJI FlightHub 2 into a single integrated system, it reduces battery-related downtime and streamlines third-party alert-triggered dispatch after operator confirmation.
For Dock as First Responder (DFR) programs, that means rapid dispatch after an operator confirms the alert, with no pilot on site needed and shorter battery-related downtime between calls. For infrastructure inspection and security teams, the same airframe handles telephoto, infrared, and AI-powered detection without swapping equipment between day and night missions. For dense or complex sites, the required DJI O4 Ground Station, onboard obstacle sensing, and appropriate site planning work together to support deployment, subject to positioning coverage and local conditions.[4][5]
Whether you're managing emergency response coverage, infrastructure inspection routes, or large-scale security operations, DJI Dock 4 is designed to keep your fleet ready for repeated missions call after call, shift after shift.
To learn more or arrange a product demonstration, contact your local DJI Enterprise dealer.
Disclaimers
[1] Currently, only FlyTo Tasks support flight speeds of up to 21 m/s. In other modes, the maximum flight speed is 15 m/s.
[2] Time elapsed from when the Dock Cover is fully closed to the completion of the battery swap. Measured in a controlled test environment and is for reference only.
[3] With the DJI AP1 Parachute installed, DJI Matrice 5TD meets EU C5 and UK5 operational requirements (STS-01), and EU C6 and UK6 operational requirements (STS-02).
[4] mmWave radar may be unavailable or restricted in some countries or regions. Obstacle sensing and bypass performance vary with weather and obstacle material, position, and shape. Refer to local regulations and the user manual.
[5] High-rise deployment depends on satellite positioning coverage and currently supports most Asia-Pacific regions. Install the O4 Ground Station in an open area and conduct an on-site survey before deployment. Refer to the Installation and Setup Manual.
The data referenced in this article was measured for the mass-production DJI Dock 4 and DJI Matrice 5TD in a controlled test environment. Results may vary under different external conditions, usage, and firmware versions.
Always comply with local drone laws and regulations when operating. Contact an authorized DJI dealer or DJI After-Sales Support if you experience any issues with your equipment or software.
