DJI Pilot Plugin: Reuse Proven Flight Capabilities
DJI Pilot Plugin: Reuse Proven Flight Capabilities Business
November 30, 2026
Integrating an industry system into drone operations often requires building foundational capabilities, such as video transmission and maps, from scratch. This can be time-consuming and costly. DJI Pilot Plugin allows industry applications to reuse proven operational capabilities, reducing low-level development work so developers can focus on their core business. Plugins run inside DJI Pilot 2 (Pilot) and provide business-specific workflows through a floating window and Pilot’s open UI.
Plugins in Action: Three Industry Scenarios
From task execution and spatial annotation to recognition feedback, industry applications rely on robust underlying capabilities. The following scenarios illustrate how Pilot’s open capabilities and native MSDK capabilities can be used in practice. Use them as inspiration rather than fixed solutions: these capabilities can be combined to suit your business needs.
Emergency Search and Rescue: Spatial Overlays for On-Site Assessment
At an emergency scene, every second counts. Smoke and low light can make it difficult for operators to identify assembly points and evacuation zones in relation to the rescue site. With a Pilot plugin, key locations can be marked on the map and projected onto the live camera view using AR. Operators can use the remote controller screen to compare spatial positions, assess the situation, and deploy rescue resources more quickly. Where supported by the plugin, annotations and the live view can also be shared with ground teams and incident command.
• Map Widget: Display task points, operational routes, and areas of interest together on the Pilot map, with tap interactions.
• AR Projection: Overlay annotations on the camera view based on their latitude, longitude, and altitude. The overlays update as the viewing angle changes. They are for reference only and do not constitute flight restrictions.
Facade Inspection: Route Planning and Task Handover on the Remote Controller
Facade inspection often involves transferring data between a computer and a remote controller, and missed flights can be difficult to identify. Pilot handles flight operations, while WallGuardian adds a business layer for project and building records, task handover to Pilot’s route library, progress tracking, and 3D visualization. This allows on-site teams to access their work directly from the remote controller.
• Wayline Task Management: Import project routes, or waylines, into Pilot’s route library, where operators can review them and decide when to fly.
• Maps and Layers: Display buildings, base maps, and 3D models on the remote controller to help teams check progress on site.
Compliance and Inspection: Built-In Checks and On-Site Route Planning
Professional pilots who fly every day often want to retain the familiar Pilot experience. The DroneRoofer plugin builds on that experience by adding compliance and site-specific flight workflows: a pre-flight check, a route drawn on site, airspace restrictions displayed during flight, and a pre-filled flight record after landing.
For example, under Japan’s Civil Aeronautics Act, pilots must maintain inspection and flight records and confirm whether they are permitted to fly in the relevant airspace. The plugin incorporates these steps into the normal flight workflow.
• Built-In Compliance: A pre-flight wizard records the inspection, airspace restrictions are color-coded on the map during flight, and the flight record is pre-filled after landing. The pilot selects the applicable regulatory category.
• Freehand Route Planning on a Photo: Draw a route on a photo taken on site. The route is exported to Pilot’s route library and flown using Pilot’s standard waypoint feature. In the demo, a drawn line was converted into 38 waypoints, with a flight time of approximately 1 minute and 50 seconds. These figures are from the demo.
From Scenario to Plugin: Faster Development and Validation with OPW
Once you have defined your scenario, you can use OPW (Open Pilot Wizard)*, a plugin development assistant, to accelerate development. Whether you are creating a new MSDK app or adapting an existing one, you can use natural-language instructions to support the development process. After building the plugin on a computer, install it on the remote controller to validate its integration with Pilot and test your business workflows.
* OPW works with mainstream AI coding tools such as OpenCode, Claude Code, and Codex.
OPW Development Resources:
• Developer Documentation
• API Documentation
• Open-source Demo
• OPW
Reach the Global Ecosystem with App HUB
After validation, plugins can be submitted for review and listing on DJI App HUB, where they can be showcased and distributed to Pilot users worldwide. Users can open App HUB in Pilot on their remote controller to browse, download, and install the plugins they need.
Supported products: DJI Matrice 5T, Matrice 4E/4T, Matrice 4D, and Matrice 400.
Tags: Matrice 4 Series, Matrice 400, Matrice 5TD
Matrice 4 Series | Matrice 400 | Matrice 5TD
Integrating an industry system into drone operations often requires building foundational capabilities, such as video transmission and maps, from scratch. This can be time-consuming and costly. DJI...
Matrice 5TD | DJI Dock 4
