DJI Matrice 400 vs 350: LiDAR Efficiency Comparison
A Detailed Side-by-Side Analysis of LiDAR Performance for Professional Surveying
By Run Li Run Li
August 15, 2025
In this article, we will be using the M400 + L2 and M350 + L2 to show the differences in workflow and efficiency with the enhanced M400 system equipped with the same L2 payload.
First, based on the specifications of both systems, the M400 when equipped with the L2 has a flight time of 59 minutes, which is 40% longer compared to the M350 or M300. This difference increases to 53 percent when we compare the estimated maximum effective flight time, which only accounts for the mission duration. When applying the estimated maximum effective flight time to the mission planner, we have a clear comparison in terms of operation site coverage at different flight altitudes. Overall, due to longer effective flight time, the M400 provides over 80 percent more coverage per flight when compared to the M350 or the M300.
M350vsM400
*The maximum effective time refers solely to the mission duration between the first and last waypoints, excluding other operational phases such as UAV takeoff, transit to the first waypoint, return to the home point, and landing. These segments are considered non-effective mission time as they do not contribute directly to data acquisition. For comparison purposes between different systems, a standard deduction of 10 minutes is applied to account for this non-effective time. However, this value may vary depending on Return-to-Home (RTH) settings and can be further influenced by real-world factors such as wind conditions, terrain complexity, and weather. ** The mission was configured with 60% side overlap and 70% front overlap for LiDAR data collection. Efficiency mode was disabled to prioritize data quality, and IMU calibration was enabled. Elevation optimization was not applied. The flight boundary was defined using a square shape; however, due to the complexity of the actual polygonal boundary, the IMU calibration sequence may be extended. This is caused by the need for mid-route calibration and additional corrections during turns. Please note that real-world performance may be further influenced by environmental factors such as wind conditions, terrain variation, and weather.
However, all these comparisons are based on estimated performance from the system specifications and assume optimal conditions. How do both systems actually perform in real-world scenarios? To find out, we set up a test comparing the M350+L2 and M400+L2 side by side—same day, same site, same weather conditions, and similar mission parameters.
1. Preparation:
In collaboration with the DJI certified surveying partner Cansel and CA5 Survey, we secured a comprehensive test site in Big Rock, Malibu, California. This 160-acre location was partially damaged during the 2025 California wildfires. The fires, which ravaged over 250,000 acres across Southern California, were among the most destructive in the state's recent history, fueled by extreme drought conditions and unusually strong Santa Ana winds. Several structures within our test site were destroyed, creating a real-world scenario requiring detailed reconstruction surveys for insurance claims and rebuilding efforts.
The site features varied terrain (including steep hillsides and flat areas), diverse vegetation conditions (ranging from completely burned to partially affected areas), and structural remains, for comparing drone performance in post-disaster recovery applications. For this assessment, we deployed the DJI L2 LiDAR sensor on both drone platforms to capture high-resolution ground data, enabling digital terrain following capabilities for the M350 and the more sophisticated real-time terrain following functionality available with the M400.
image (6)
 DJI FlightHub 2 - Mission Planning for M400 +L2
2. Mission Planning:
For the M400, the process works as follows:
First, we need to define the boundary of our scan. This boundary is determined and reviewed by the survey team to ensure it sufficiently covers the operation site. The boundary polygon can also be shared with the ground team for safety awareness, letting them know when and where the drone will be operating.
Workflow - Transfer KML shape boundary file to DJI Pilot 2 app or DJI FlightHub 2 app
We then used DJI FlightHub 2 to create missions for the DJI M400, then synced them to the DJI Pilot 2 app via cloud sync, which synchronized the KMZ mission files. While we could have planned missions directly using the DJI Pilot 2 app on the remote controller, creating them on a desktop is more convenient. FlightHub 2 runs in a web browser environment, eliminating the need to handle the remote controller for mission planning. Additionally, since missions are stored in the cloud, multiple team members can access and modify them online, ensuring the mission is always up to date when needed. DJI FlightHub 2 does not support mission planning for the M350 platform. To work around this, we downloaded the M400 L2 mission in the Pilot 2 app (which had been synced from FlightHub 2), modified it within Pilot 2, and changed the platform from M400 to M350. This approach preserved all sensor and flight settings.
Workflow - Mission files can be transferred and kept in sync between the cloud and the local remote controller
To ensure a fair comparison between the two platforms, we used identical payload settings, flight altitude (325ft AGL), flight speed (20 mph), overlap ratios (60% side and 70% forward), and flight boundaries.
Due to the site's significant terrain variations, we implemented terrain following for both the M350 and M400 flights to obtain uniform Ground Sampling Distance (GSD) and consistent LiDAR point density throughout the entire survey area; however, each platform used a different approach:
The M400 features real-time terrain following for both mapping missions and manual flights. This is achieved through its more advanced visual sensors. We only need to set the above ground level elevation under the mission planning with in FlightHub 2 and enable the Real Time Terrain Follow option, and the system automatically maintains consistent altitude over varying terrain during the flight.
M400 Vs M350DJI FlightHub 2 - Real-time Terrain Follow option in mission planning
DJI Pilot 2 - DJI M400 Real time Terrain Follow in action
For the M350, which lacks the Real-Time Terrain Follow feature available on the M400, we needed to apply a terrain or surface model in the Pilot 2 mission planning interface. This required obtaining terrain data of the site to generate the terrain-follow route. In the mission planning settings, we first selected "AGL" (Above Ground Level) as the altitude mode, then selected "DSM Files" to add the terrain or surface model in the Pilot 2 app to serve as reference terrain.
DJI Pilot 2 - Enable Terrain Following
There are two options available. The first, "Import Local File," requires importing a DSM/DEM file in geotiff format with WGS84 and Ellipsoidal height system in meter units. The second option, "Download from Internet," allows the Pilot 2 app to directly download the ASTER GDEM V3 30-meter resolution model based on the mission boundary. Both the M350 and M400 support DSM/DEM file import and ASTER download for terrain following.
 DJI Pilot 2 - M350 Terrain Following Route after apply the ASTER GDEM
While the second option is more convenient, ASTER GDEM often fails to account for real-time terrain changes due to outdated data, and its 30m resolution may not accurately represent terrain variations. To ensure optimal results with uniform point density and ground sampling distance, we processed high-resolution DSM from previously captured M400 L2 photogrammetry data. We processed this dataset with low-resolution output settings on-site using DJI Terra software for optimal processing speed on site, once done, we then selected "Import Local Files" to load the transferred DSM file for mission planning.
DJI Pilot 2 - Terrain Following file options
During this mission planning phase, we noticed that the workflow is significantly simplified with the M400's real-time terrain following capability. The M350's requirement for DSM/DEM files adds extra work and introduces potential human operation error risks related to file format, coordinate system, and import size limitations.
We could have used the ASTER GDEM to simplify this process; however, using potentially outdated terrain models creates uncertainty for operations in sites with frequent terrain changes, such as mining and construction scenarios. Therefore, importing processed DSM is a more reliable approach for these situations.
Workflow - M400 and M350 Terrain Follow Comparison
After creating both missions, we immediately observed an 8-minute difference in flight duration—an approximate 18% improvement in efficiency with the M400 compared to the M350. Since both flights used the same speed, altitude, and mission parameters, we initially attributed the discrepancy to differences in terrain following behavior. The M400 uses real-time terrain following, while the M350 calculates elevation changes in advance based on the imported terrain model.
Our initial hypothesis was that the M350's preplanned terrain-following route would more accurately represent real-world flight saturation, while the M400’s route might appear artificially shorter due to not accounting for actual elevation changes during mission planning. We suspected that the 8-minute gap would eventually be filled during the M400's flight as it ascended and descended in response to terrain in real time.
However, our results disproved that assumption. In practice, the M400’s real-time terrain following is precisely what enabled the 16% improvement in flight efficiency.
DJI Pilot 2 - Estimated Flight Time
3. Data Acquisition:
The survey technician with CA 5 Survey first set up 23 control targets across the operation site with recorded state projection coordinates. These targets serve to validate the UAV system's precision and accuracy, and can also constrain the model to improve absolute accuracy. Each control point was placed on a GCP target with reflective markings to make them easier to identify in point cloud reflectivity views.
DJI Terra - GCP Target Distribution
The DJI D-RTK 3 was utilized as the correction reference station during data collection. RTCM data recorded from the base was later submitted to OPUS to obtain a more precise solution for the D-RTK 3's APC (Antenna Phase Center) coordinates. These refined coordinates were then used to update the original base station position in DJI Terra. The updated base position was subsequently applied in both the PPK processing of M350 RTK with L2 data and the RTK processing of M400 RTK with L2 data, ensuring improved geolocation accuracy across both datasets.
4. Data Processing:
Both the M400 and M350 datasets were processed using DJI Terra, and the overall workflow is identical for both platforms. Since the M350 was operated without RTK, its data was processed in DJI Terra using the PPK workflow. However, in terms of processing steps, there is no difference between the two datasets. When equipped with payloads such as the Zenmuse L2 or P1, both platforms support RTK and PPK workflows for post-processing.
DJI Terra - M400 + L2 flight trajectory
DJI Terra - M400 + L2 point-cloud processed
DJI Terra - M400 + L2 DSM processedDJI Terra - M400 + L2 DSM processed
DJI Terra - M400 + L2 Contours processed
5.Efficiency Comparison
In this scenario, we tested a 160-acre site using both M400 and M350 platforms. From this real-world test, we found that high wind conditions and significant terrain variations caused frequent aircraft ascending and descending during operations. These factors affected the accuracy of our mission time estimations.
For the M350: For the M400:
Completed in two flights total, total effective operation time (from first waypoint to last waypoint in mission route) is 45 mins (First Flight: 24mins + Second Flight: 21mins) Completed in two flights total, total effective operation time (from first waypoint to last waypoint in mission route) is 38 mins (First Flight: 35mins + Second Flight: 3mins)
Comparison
Comparison - First Flight Coverage
6. Key Challenges with the M350 System
  • Outdated Elevation Data: Acquiring current DSM/DEM for accurate terrain-following is difficult with the M350. Preplanned missions often fail to reflect real-time terrain changes, demanding constant operator attention.
  • Operational Complexity: For large mapping areas, the M350's shorter flight time requires frequent battery changes, which increases RTK reconvergence delays and creates more opportunities for human error.
M400 Improvements
Real-Time Terrain Following: The M400 offers real-time terrain following for both mapping missions and manual flights. Operators simply set the desired above-surface elevation, and the system automatically maintains consistent altitude over varying terrain. This ensures uniform Ground Sampling Distance (GSD) and consistent LiDAR point density across the entire survey area.
Extended Flight Efficiency: The M400's longer effective flight time allows greater area coverage per mission. This reduces battery swap frequency, streamlining field operations and improving overall data collection efficiency.
Improved Data Quality: With real-time terrain following and fewer mission interruptions, the M400 delivers more consistent, higher-quality datasets requiring less post-processing correction.
7. Conclusion
Special thanks to Cansel and to Chris Nelson, PLS at CA 5 Survey, for their collaboration in organizing and executing this efficiency comparison test. Our testing and comparative analysis show that the M400 platform offers a clear efficiency advantage over the M350 when performing LiDAR mapping at midsize operational sites. This advantage stems from key platform improvements, including extended flight endurance, enhanced real-time terrain following, and streamlined operational complexity. These capabilities collectively result in significantly higher coverage efficiency per flight, reducing the need for frequent battery swaps—particularly on larger sites—without compromising data quality.
Under identical conditions, the M400 demonstrated a 16% improvement in overall flight efficiency and achieved approximately 39% greater single-flight coverage compared to the M350.
Efficiency Comparison - Flight Time and First Flight Coverage
Tags: Matrice 400
Matrice 400 Webinar
Run Li
About the Author Run Li
Run Li is a Solutions Engineer at DJI Enterprise, specializing in the development of innovative geospatial solutions using unmanned systems. With a strong focus on optimizing adaptive daily UAV operations, Run Li's contributions have been instrumental in driving the advancement of next-generation solutions at DJI Enterprise. Through his industry insights and expertise, he has played a vital role in shaping the development and success of DJI's geospatial offerings.
Regulations
Software Update | FlightHub 2
AEC & Surveying | Zenmuse L3
