A 1K thermal camera, wire-level obstacle sensing, and open onboard AI in a single airframe small enough to carry in one hand. Here is what is new, and which jobs each upgrade actually changes.
November 5, 2026
Most enterprise drone programs do not fail in daylight. They fail at 21:00 on a substation inspection with a thermal camera that cannot resolve the hotspot, in a rain squall that grounds the aircraft, or in a valley where the video link dies two kilometres from the pilot.
DJI Matrice 5T is built around those three failure points. It puts a native 1K thermal camera and full-color night vision in the same airframe as LiDAR, mmWave radar, and an omnidirectional vision system, rates the whole assembly IP55, and keeps it in the air for up to 59 minutes.[1] It also opens the onboard compute to third-party models and adds multiple relay modes for terrain that blocks a direct link..
This guide covers the eight upgrades worth knowing, what each one changes on a real job, the software and developer stack behind them, and the specs most people ask about first.
Quick answer: DJI Matrice 5T is a compact enterprise drone with a 1K thermal camera, full-color night vision, LiDAR and mmWave radar obstacle sensing, IP55 protection, up to 59 minutes of flight time, O4 Enterprise transmission with multiple relay modes, open onboard AI, and centimeter-level surveying without ground control points.
1K Thermal Imaging, Enhanced Night Vision
The thermal camera captures at a native 1280x1024, four times the pixel count of a standard 640x512 sensor, and Ultra-High-Resolution mode outputs 2560x2048 at 30 fps. On a solar farm or a transmission tower, that resolution is the difference between "there is a hotspot in this string" and "this is the panel." Heat anomalies stay defined even against cluttered backgrounds.
Night work does not need a separate payload either. The wide camera pairs a 1/0.98-inch sensor with an f/1.8 aperture and AI low-light enhancement, reaching ISO 1,600,000 for full-color imagery at 0.01 lux.[2] The 50 MP medium telephoto resolves pins and cracks from 10 metres and reads instrument data at substations,[3] the 50 MP telephoto reads plates from 400 metres,[4] and the NIR auxiliary light adds useful detail at close range.[5]
Two additions matter more than the sensor list. The laser rangefinder measures to 3 km[6] for pinpointing, line drawing, and area calculation, so assets get marked without a second pass on a map. And dual-light fusion runs on the remote: thermal and visible feeds overlay on one screen with a dial for blend ratio, so an operator sees where the heat is and what it belongs to at the same time.
Matrice 5T Solar Farm Inspection
Omnidirectional Sensing [7], IP55 Rating [8]
This is the first DJI compact enterprise drone to carry LiDAR, mmWave radar, and omnidirectional vision together. That combination is what makes the IP55 rating useful rather than decorative.
LiDAR picks out thin obstacles at night and detects power lines up to 32 m away.[9] MmWave radar keeps sensing through fog, rain, and dust, where vision systems degrade. The low-light vision system holds positioning down to 0.5 lux using full-color fisheye sensors,[10] and Vision Assist now shows full-color imagery instead of a grey feed. In poor GNSS, under a bridge, inside a canyon, or between high-rises, the aircraft fuses visual and radar data to map its surroundings and hold position.
Airspace awareness is included as well. Built-in ADS-B and RID receivers detect nearby manned and unmanned aircraft and issue alerts, which matters for teams flying multiple aircraft in the same corridor.
DJI Matrice 5T LiDarmmWave radar
Open Edge AI, On-Site Intelligence
More than 20 target types are detected natively, across both thermal and visible feeds on a split screen. Vehicles, vessels, and fires[11] are recognised in flight, not after the footage comes back.
Three things separate this from a fixed detection library. First, the onboard compute is open: teams can deploy their own YOLO-based models, so a utility with a trained insulator-defect model is not waiting for a firmware release. Second, connected to DJI FlightHub 2, cloud detection accepts text or image prompts through a multimodal model, which turns a search for "white truck near the north gate" into a result. Third, AI Patrol Routes close the loop. Trace an area on the map, and the aircraft builds the route, detects targets, hovers, captures, records, or broadcasts on cue, then compiles a report when it lands.
For a security or inspection team, that is the difference between a drone that records and a drone that reports.
DJI Matrice 5T with spotlight on
O4 Enterprise Transmission, Multiple Relay Modes [12]
O4 Enterprise Enhanced uses the sub2G band[13] and a high-gain smart antenna array to reach up to 40 km.[14] Adaptive multi-band switching resists urban interference, and dual built-in DJI Cellular Dongle 2 modules switch to the strongest network link automatically.[15]
The relay options are where complex terrain gets solved. A single relay drone extends one operational aircraft. One remote can fly both the relay and the working aircraft, with the relay adjusting its own position to hold the link. One relay can serve two operational aircraft at once for coordinated multi-drone work. And two relays in series push the link further still, for valleys, ridgelines, and signal-blocked corridors.
DJI Matrice 5T in use for public safety
Powerful Propulsion, Extended Flight Time [1]
A 215Wh battery gives up to 59 minutes of flight, measured in a controlled wind tunnel at roughly 9 m/s with no payload.[1] One takeoff covers more ground, and fewer battery swaps mean less time with the aircraft on the ground.
Two details are more operationally useful than the headline number. The aircraft powers on and takes off in 10 seconds, which is what makes it credible for an emergency call. And the power redundancy is real: single-axis thrust is up 98% over Matrice 4T,[16] a phase-loss algorithm detects faults in milliseconds, and an affected arm still delivers 50% of max thrust[16] for a controlled hover and landing. Standard propellers use a swept-tip design that brings noise down to 80 dB(A).[17]
DJI Matrice 5T inside carry case
Next-Generation Core Accessories [18]
The DJI RC Plus 3 Enterprise carries a 7.44-inch, 2000-nit screen that stays readable in direct sun, with the high-gain antenna array and Cellular Dongle 2 built in, so no external modules are needed, and up to 6 hours of runtime.
The rest of the set fills specific gaps. The DJI AS2 Speaker broadcasts to 400 m and reaches 120 dB at 1 m, with text-to-speech, looping, and an integrated warning light. The DJI AL2 SpotLight follows the camera through its full tilt range, which is what makes under-bridge work at night practical. And the charging hub outputs up to 515W, taking batteries from 10% to 95% in 31 minutes in Standby mode,[19] with the remote charging at the same time.
Matrice 5T with accessories
High-Accuracy Surveying, Rapid Modeling
Paired with DJI Terra, the aircraft delivers centimeter-level accuracy without ground control points.[20] That removes the step that usually decides whether a small site gets surveyed at all.
Four capabilities carry most of the work. Thermal images stitch into 2D thermal orthomosaics using visible-light positioning as a reference, with temperature readable and anomalies markable directly on the map. Images stream to the remote during flight to build local point clouds or 2.5D models, with annotation and measurement on the model and 200 photos processed in about 8 minutes.[21] A rough model built first lets the aircraft plan a route that follows the subject's surface, so detailed modelling finishes in a single flight.
For solar, grid, and facade inspection, the thermal orthomosaic is the piece that turns a flight into an asset register.
DJI Matrice 5T bridge inspection
Multi-Mission Adaptability, Custom Pilot Plugins
The last upgrade is the one that decides whether the aircraft fits an existing workflow.
Foreground stabilisation uses an onboard segmentation model to separate a subject from its background during telephoto shooting, so a conductor or a crack stays sharp while the background moves. Top-mounted LiDAR locks onto power and ground wires for automatic lateral flight along the line.[22] The aircraft takes off from and lands on a moving vessel, using deck pattern recognition for the landing.[23] And DJI Pilot 2 accepts custom plugins as floating windows, so a team can bring its own tooling into the flight app instead of building a separate application.
For developers, the ecosystem is open at every layer: the Intelligent Algorithm Developer programme for onboard models, MSDK V5 for custom apps, E-Port V3 with encrypted authentication for third-party payloads, and a Cloud API for direct connection to a third-party platform.
Software, Security, and the Wider Ecosystem
An "everything you need to know" guide would be incomplete without the software, because on this aircraft the software decides how much of the hardware gets used.
DJI Pilot 2 runs the flight side: Cruise, FlyTo, Smart Track, and POI automation, plus a split screen that shows preset combinations of wide, telephoto, thermal, map, and Vision Assist feeds, so the operator stops switching views mid-task. Custom plugins load as floating windows on top.
DJI FlightHub 2 runs the fleet side: cloud aircraft and gimbal control, remote takeoff and landing, route planning including geometric and slope routes, multimodal target search by text or image, and simultaneous live feeds that keep air and ground teams on the same picture.
DJI Terra turns the flight into a deliverable, outputting 2D, 3D, and point cloud models, with 2D thermal mapping, rolling-shutter reconstruction, and video frame reconstruction for cases where the imagery was not captured as a planned survey in the first place.
DTAT 3.0 handles thermal analysis after the flight, marking and processing images to isolate temperature anomalies, which is the step that turns a thermal orthomosaic into a defect list.
Data security is covered at four points: media data encryption, Local Data Mode, one-tap log clearing, and AES-256 encryption on the video transmission link.
Service includes a complimentary first year of either DJI Care Enterprise Plus or the Official Extended Warranty Service.[26] DJI Care Enterprise Plus adds unlimited free repairs within coverage, shared coverage across a fleet activated in the same 30-day window, flyaway coverage once a year, battery replacement, free two-way shipping, and expert support.
DJI Matrice 5T powerline inspection
Where it fits: public safety, power line inspection, GIS and surveying, oil and gas, renewable energy, water conservation, building inspection, and roads and bridges. Those are not marketing categories. Each one maps to a specific capability above, and the case for the aircraft is strongest where two or three of them overlap, as they do on a utility that both patrols lines and maps the corridor around them.
FAQ
1. Does DJI Matrice 5T need a separate thermal payload for night work?
No. The thermal camera, full-color wide camera, medium telephoto, and telephoto are built into one airframe, with thermal and visible feeds fused on the remote.
2. Can it fly in rain and dust?
It carries an IP55 rating, tested under controlled laboratory conditions, and operates from -20° to 50° C. The rating is not permanent and can decrease with wear, so check the protection notes before planning sustained exposure.
3. What does "wire-level obstacle sensing" mean in practice?
LiDAR detects power lines up to 32 m away at night, and the aircraft can sense a 21.6 mm transmission line at speeds up to 21 m/s when flying directly at it. Sensing performance varies with weather and the material of the obstacle.
4. Can a team load its own AI models?
Yes. The onboard compute is open to third-party models, with support for open-source models such as YOLO variants, and DJI FlightHub 2 adds cloud detection using text or image prompts.
5. How far can it transmit?
Up to 40 km under the IC standard in an unobstructed environment, less under SRRC, CE, and MIC standards. Relay modes extend coverage around terrain that blocks a direct link.
6. Does DJI Matrice 5T need a dock to operate?
No. It is a hand-flown aircraft controlled with the DJI RC Plus 3 Enterprise, built to be carried and launched on site. Dock-based automation is a separate product line.
7. Can it carry third-party payloads and software?
Yes. E-Port V3 supports third-party payloads with encrypted authentication, MSDK V5 covers custom applications, and DJI Pilot 2 accepts plugins, so existing tools can be brought into the flight app rather than rebuilt.
Get Started with DJI Matrice 5T
DJI Matrice 5T is a compact flagship built for the jobs that normally force a compromise: a thermal camera that resolves the defect, a night vision system that keeps colour, an obstacle sensing stack that works in rain and darkness, and a link that survives terrain. All of it fits in a case one person can carry.
For inspection teams, the thermal resolution and 2D thermal mapping turn a patrol into an asset record. For public safety, the 10-second takeoff, 59-minute endurance, and ADS-B and RID awareness support longer coverage with fewer aircraft. For survey and GIS crews, GCP-free accuracy and on-site modelling shorten the loop between flight and deliverable.
To learn more or arrange a product demonstration, contact your local DJI Enterprise dealer, or check out the DJI Matrice 5T product page.
DJI Matrice 5T outdoor image
Disclaimers
[1] Measured in a controlled wind tunnel environment under conditions equivalent to a windless environment at sea-level altitude, with the aircraft flying forward at approximately 9 m/s without payloads until reaching 0% battery level. Data is for reference only. Actual flight time may vary depending on flight mode, accessories, and environment.
[2] Measured in a specific test environment with Night Scene mode enabled and ISO set to the maximum of 1,600,000. Actual results may vary with atmospheric visibility, target reflectivity, and light pollution.
[3] Measured under standard lighting conditions from a horizontal position 10 metres from the subject, with a direct line of sight.
[4] Captured with the tele camera directly facing the subject.
[5] The NIR auxiliary light is intended for the lighting needs of the tele camera. Measured with the aircraft hovering 100 metres above the ground with the tele camera effectively capturing images.
[6] Measured at 25° C with visibility above 8 km, target reflectivity above 25% at 905 nm, and the LiDAR beam striking the target perpendicularly.
[7] Refer to the user manual for operating conditions and precautions of the omnidirectional vision system. Positioning and obstacle-sensing performance may be affected by the flight environment and obstacle characteristics.
[8] Tested under controlled laboratory conditions to IP55. IPX5 water test: 6.3 mm nozzle, 12.5 L/min, approximately 30 kPa, 2.5 to 3 m distance, at least 1 minute per square metre and 3 minutes total, sprayed from all directions. IP5X dust test: dry non-abrasive fine dust, 2 kg per cubic metre, 8 hours, sealed chamber. The rating is not permanent and may decrease with normal wear.
[9] Measured with a 21.6 mm steel-core aluminium stranded wire inside the LiDAR field of view, in sunny conditions with illuminance below 35,000 lux.
[10] Without the spotlight or speaker installed. The vision system cannot detect surfaces without texture or below 0.5 lux. Below 12 lux the visual sensor switches to black-and-white mode.
[11] Fire detection is available only in the visible-light camera view.
[12] Unavailable in countries or regions without 5GHz support.
[13] Not available in some countries and regions. Check local laws and regulations.
[14] 40 km under the IC standard; 20 km under SRRC in Mainland China, CE in Europe, and MIC in Japan. Measured in an unobstructed environment free of interference, one-way non-return flight.
[15] Requires cellular network coverage.
[16] Single-axis thrust comparison against Matrice 4T under identical laboratory conditions, both at equivalent sea-level windless conditions with the propulsion system secured to a test bench. Actual payload is affected by configuration, attitude, and environment.
[17] Measured in accordance with GB 42590-2023, at 4.5 m test distance, with the ground point at 0.5 m and the side point at 5 m height.
[18] Listed accessories are sold separately.
[19] Measured at 25° C in Turbo mode. Performance may be affected by ambient temperature, and power may be throttled due to overheating. Charging times increase at lower or higher temperatures.
[20] Requires DJI Terra. Offline visible-light PPK and D-RTK 3 imports improve reconstruction accuracy for GCP-free operations.
[21] Measured with interference below -90 dBm and the aircraft within 500 m of the remote, timed from completion of image capture to final output.
[22] In windless conditions, supports single, twin, quad, hexa, and octo-bundled conductors and ground wires, with inclination under 40°.
[23] Recommended at ship speeds below 10 knots and wind speeds below 5 m/s, with a 3 m x 3 m deck space reserved. Landing point pattern files are available on the download page.
[24] Measured in a controlled wind tunnel environment under conditions equivalent to a windless environment at sea-level altitude.
[25] 515W is the maximum output of the DJI Matrice 5 Series Charging Hub. Charges batteries from 10% to 95% in 31 minutes in Standby mode at 25° C. Performance may be affected by ambient temperature, and power may be throttled due to overheating.
[26] Value-added service offerings may vary by country or region. Consult your local dealer for details. Shared coverage applies to DJI Enterprise products activated and bound to DJI Care Enterprise Plus within the same 30-calendar-day period. Flyaway coverage requires linking your account and binding the remote controller in DJI Pilot 2. Free two-way shipping is available in regions covered by DJI Care Enterprise. Official Extended Warranty Service covers the aircraft body, gimbal camera, remote controller, and charging hub.
All data in this article was collected with a production model of DJI Matrice 5T in a controlled test environment. Actual experience may vary depending on environment, usage, and firmware version. Always check and follow local laws and regulations, and confirm all required permits before flight.
Tags: Public Safety, Power Line Inspection, DJI Matrice 5T, Inspection & Surveying
