Top Features of the D-RTK 3
Maximized Precision, Enhanced Range
February 7, 2025
The game-changing D-RTK 3 Multifunctional Station by DJI has arrived, bringing groundbreaking precision and versatility to drone operations. Whether you're seeking high-precision positioning for surveying and mapping or need a reliable image transmission relay for inspection or search and rescue operations, the D-RTK 3 offers unparalleled performance and adaptability.
The D-RTK 3 Multifunctional Station is designed to meet the needs of enterprise users with its advanced components and features. It boasts high-performance air dielectric antennas with millimeter-level phase center accuracy, ensuring exceptional precision. The station supports data from five global navigation systems across 19 frequency points, offering extensive satellite compatibility. Its flexible transmission capabilities include Broadcast Mode, Relay Mode, and Rover Mode for adaptable operation. Additionally, it integrates seamlessly with DJI Enterprise drones, DJI Terra, and the DJI Enterprise app, making it ideal for mapping and precision tasks. Compatible with drone series such as the Matrice 4 Series, Matrice 300 RTK, and Mavic 3 Enterprise, the D-RTK 3 delivers unmatched versatility for enterprise operations.
KV美图
Centimeter-Level Positioning for Maximum Accuracy
Precision is at the core of the D-RTK 3’s performance. With its advanced filtering antenna design, this system delivers reliable centimeter-level accuracy, even in challenging environments. Whether operating in urban areas with significant obstructions or remote locations with limited connectivity, the D-RTK 3 ensures exceptional precision. It supports standalone Precise Point Positioning (PPP), providing decimeter-level accuracy even in areas with weak internet connectivity. Additionally, it effectively manages multi-path interference while tracking low-elevation satellites. This makes it an ideal solution for high-precision applications like mapping, inspection, and 3D modeling.
卫星信号@2x
Precision-focused design
Broadcast Mode - Seamlessly Manage Multiple Drones
The D-RTK 3’s Broadcast Mode allows multiple devices to connect simultaneously without additional configuration, making it ideal for businesses managing large drone fleets. With O4 Enterprise video transmission and directional antennas, it ensures stable video transmissions over distances of up to 15 km. This technology enables seamless multi-drone connectivity, providing precise positioning for all units. It is particularly useful for agriculture businesses coordinating drone fleets for crop spraying, as well as enterprises conducting multi-drone surveys, inspections, or emergency response operations.
广播模式@2x
The Broadcast mode is compatible with the DJI Enterprise product range.
Relay Mode - Extend Operational Range Beyond Limits
Relay Mode can support the new Matrice 4 Series. When deployed at an elevated location, it can potentially extend the operational range when there are obstacles between the RC and the aircraft. The system monitors obstructions in real-time and calculates optimal positions to ensure clear signals between drones, controllers, and relay stations. This feature is particularly useful for urban operations, where tall structures can disrupt signals, and for surveying remote landscapes such as mountainous terrains or deep valleys.
功能图特写
Enhanced transmission in high-interference areas
Rover Mode - Adaptability for Aerial Surveying
Flexibility is a key advantage of the D-RTK 3, which can also function as a rover station for precise control point coordinates collection during drone mapping projects. It works seamlessly with DJI Enterprise APP to efficiently create high-precision maps and simplifies workflows with tilt compensation, allowing measurements without needing the rover pole to be perfectly vertical. Additionally, it enables one-click export of ground control point data for processing in DJI Terra. Surveyors and cartographers will appreciate how Rover Mode enhances operational accuracy while significantly reducing setup time.
7d3d0ffc-67e5-4020-8aa9-58e54d8f9804Capture of control points with the D-RTK 3 station
DJI Terra Integration - Streamlined Workflows
The D-RTK 3's integration with DJI Terra streamlines aerial surveying, making it faster and more efficient than ever. Data collected by the D-RTK 3 can be easily imported into DJI Terra for post-processing, enabling the quick generation of maps and 3D models. It supports both PPK (Post-Processed Kinematics) and RTK (Real-Time Kinematics) workflows, ensuring compatibility with various surveying needs. Additionally, it allows projection coordinate conversion, making it simple to output planar coordinates in mainstream formats. This seamless collaboration provides surveyors with a comprehensive end-to-end mapping solution.
Performance Highlights of the D-RTK 3
The D-RTK 3 Multifunctional Station excels in real-world scenarios where precision and flexibility are essential. It offers standout features such as ionosphere resistance, outperforming network RTK systems by maintaining stable operation even during ionospheric disruptions. Additionally, it supports multi-frequency access with 19 frequency points, providing greater reliability compared to single-frequency systems. Field tests have shown that the D-RTK 3 significantly reduces error margins in complex environments, setting a new standard for reliability and performance.
Elevate Your Drone Operations with the D-RTK 3
The DJI D-RTK 3 Multifunctional Station offers the ideal balance of precision, versatility, and technological innovation. Whether you're seeking high-precision positioning for surveying and mapping or need a reliable image transmission relay for inspection or search and rescue operations, the D-RTK 3 delivers cutting-edge solutions tailored to your needs.
Enhance your drone operations—order the D-RTK 3 Multifunctional Station today and experience the future of aerial positioning and surveying solutions.
Supported Models
Relay Station Mode [1]:
  • Supports Matrice 4E/Matrice 4T
Broadcast Mode:
  • Enterprise: DJI Matrice 4 series, DJI Matrice 3D/3TD (aircraft only)*, Matrice 300 RTK/Matrice 350 RTK*, Matrice 30 Series*, DJI Mavic 3 Enterprise Series*
  • Agriculture: T60*, T50/T25*, T40/T20P*, DJI FlyCart 30*
  • Professional Filmmaking: DJI Inspire 3*
[1]This feature is unavailable in countries or regions without 5GHz frequency support. Check local laws and regulations for more information.
* Currently, only manual D-RTK 3 position calibration is supported. Please refer to official updates for future feature enhancements.
使用环境特写
Tags: Drone Ecosystem, D-RTK3
Try DJI Terra for Free Now
